Launch ANSYS Workbench and receive the error “The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.” Reinstall prerequisites and software doesn’t help.
March 17, 2023 at 1:11 pm
SolutionParticipantPlease refer to the attachments to access the Solution.
1. 2056534.pdf
