KR117: Why is the mass flow rate of a chemical species into the domain not equal to the product of the mass fraction and the bulk mass flow rate?
Tagged: 14, fluent, fluid-dynamics, General, Reactions, species-transport, Species/Reactions
January 25, 2023 at 7:17 am
FAQParticipantThe net mass flow rate of a species at an inlet boundary includes contributions from both convection and diffusion. The convection component is determined from your input of species concentration while the diffusion component is calculated by FLUENT, as long the option “Inlet Diffusion” is on in the “Species Transport” panel. From version 15 on, the option “Inlet Diffusion” is deactivated by default.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
