Keyboard not working in Fluent The lack of keyboard responsiveness for Fluent, CentOS 7.x, is showing an error in the Fluent.xxx.e file: xkbcommon: ERROR: failed to add default include path /usr/share/X11/xkb
March 17, 2023 at 9:01 am
FAQParticipantThe resolution is to install the package xkeyboard-config-2.11-3.el6.noarch
