Structural & Thermal
It is possible to change the normal stiffness factor of a contact pair between the load steps using the Contact step control object.
    • FAQFAQ
      Participant
      Yes, the Contact step control can be found by picking on the environment branch in the Mechanical tree (such as Static Structural) and then picking Conditions in the toolbar. There you will find the Contact step control object.
