April 13, 2023 at 7:32 am
SolutionParticipantDownload the patch from the attachment, then use this dll to replace the one in the corresponding installation directory of that version, e.g., under (default installation location) Windows: C:Program FilesANSYS Incv19xAddinsSimulationbinWin64 Linux: /ansys_inc/v19x/Addins/Simulation/bin/Linux64/ Note: The same dll can be used on both systems. This would allow the jobs submitted from Mechanical GUI using RSM to show up in the Workbench Job Monitor.
1. 2058164.pdf
2. 2058164.zip
