Issue starting ANSYS APDL and WB 18.2 on Windows 7 receiving the following error: ANSYS.exe – entry Point Not Found The procedure entry point for_execute_command_line could not be located in the dynamic link library libifcoremd.dll.
June 5, 2023 at 7:05 am
FAQParticipantLook for older versions of this ( libifcoremd.dll.) dll under C:Windows, C:WindowsSystem32 and SysWOW64 directories. Rename these dll’s to libifcoremd.dll.save and this will resolve the problem.
