Is there any workbench model which demonstrates the application of user defined contact normal offset?
Tagged: 19.2, contact, mechanical, structural-and-thermal, structural-mechanics
April 13, 2023 at 7:33 am
SolutionParticipantPlease see the attachment.
1. 2060711.zip
2. Contact Normal Offset.pdf
