Is there any way to stop the Fluent run once one particular variable reaches to certain value. For example, User wants to stop the solution once the maximum temperature reaches to 400k.
Tagged: 19, fluent, fluid-dynamics, General, General - FLUENT
May 15, 2023 at 8:32 am
SolutionParticipantPlease find the attached solution for it.
1. convergence_conditions.pdf
- Skewness in ANSYS Meshing
