June 5, 2023 at 7:05 am
FAQParticipantIf you load both meshes into CFD-Post, you can visually compare them. If you want a more exact comparison, export the node locations to a text file and use a file comparison tool to see whether they are the same. This can be done in either Fluent or CFD-Post. In Fluent, click File > Write > Profile and write the coordinates on the surfaces you want to compare. In CFD-Post, click File > Export > Export and select the location on which you want the coordinates exported (be sure to keep “Export Geometry Information” selected).
- Skewness in ANSYS Meshing
