Is there a way to show the element coordinate systems, so that I know what direction the bending moments are in?
January 25, 2023 at 7:34 am
FAQParticipantYes. The following steps will display the element coordinate systems: 1.Go to ‘Solution’ 2.Right click >> Insert >> Co-ordinate System >> Elemental Triads 3.Select the geometry in the ‘Scope’ options 4.Evaluate the results. It will display the elemental co-ordinate system for elements of selected geometry.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
