Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
March 1, 2022 at 10:56 pm
FAQParticipantYes. The following steps will display the element coordinate systems:
1. Go to ‘Solution’
2. Right click >> Insert >> Coordinate System >> Elemental Triads
3. Select the geometry in the ‘Scope’ options
4. Evaluate the results.
It will display the elemental co-ordinate system for elements of selected geometry.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
