Tagged: 2020 R2, fluent, fluid-dynamics, General - FLUENT, HPC / GPU / Cloud
March 17, 2023 at 8:59 am
FAQParticipantCell registers are available as Booleans in the expression system. Simply calculate the sum over the register with an if-condition. Sum(IF(
, 1, 0), [ ], Weight=”Volume”) is the name of the cell register and is the list of cell zones. If the name of the register is “myregister” and the affected cell zones “fluid1” and “fluid2″ the expression is: Sum(IF(myregister, 1, 0), [‘fluid1’, ‘fluid2’], Weight=”Volume”)
- Skewness in ANSYS Meshing
