March 17, 2023 at 8:58 am
FAQParticipantYes. – Go to ‘Edit/Options/Units’ in the CFX-Post menu – Switch the unitsystem from SI to Custom – Click on ‘More Units’ – Edit the unit entry for density manually to ‘mg m^-3’ and confirm ‘Okay’ – Activate ‘Always convert to preferred units’ – Press ‘Apply’ to see your new units in the legend
- Skewness in ANSYS Meshing
