Tagged: 19.2, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 1:11 pm
SolutionParticipantYes, this can be done by aligning the elements CS on the curved edge with the “Element Orientation” functionality. Please check the attached pdf presentation with the explained procedure.
1. 2062096.pdf
