Is there a tutorial / video / document that shows how to do a 2D Fluent analysis starting from Workbench? That is, I want to make geometry with DM, mesh from WB/ANSYS Meshing, and then do 2D analysis in Fluent.
Tagged: 17.2, fluent, fluid-dynamics, General - FLUENT
August 25, 2023 at 12:15 pm
SolutionParticipantPlease see attached document. Keywords: 2D set up, 2D geometry creation and meshing
1. 2045942.pdf
2. 2045942.zip
- Skewness in ANSYS Meshing
