June 6, 2022 at 10:33 am
FAQ
ParticipantThere may be a situation where mesh settings or shapes, for example, were only changed for some bodies after generating a mesh for a shape composed of multiple bodies. It is possible to only remesh certain bodies, by holding the meshes of the remaining bodies that are not affected. You can shorten the time required for this operation. Since this function was added from version 13.0 onwards, it is invalid in the default setting, so you need to make the following settings prior to use. In DesignModeler Tools > Options > Compare Parts On Update = Yes
Using Inventor or NX in CAD Right-click on the Geometry cell in the Workbench Project, go to Properties, and check Smart CAD Update
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Create Sections in Meshing
- ANSYS ICEM CFD: Basic Blocking
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is meaning of message: One or more objects may have lost some scoping attachments during the geometry update.
- What is the difference between patch dependent meshing and patch independent meshing?
