Is there a limit for the number of bodies in a project? Is it possible for more than one person to work on the same file simultaneously?
August 25, 2023 at 12:15 pm
SolutionParticipantPlease see attached document for solution. Keywords: limit, simultaneously, number of bodies
1. 2050306.pdf
- Skewness in ANSYS Meshing
