Tagged: 18.1, fluent, fluid-dynamics, General, General - FLUENT
January 25, 2023 at 7:16 am
FAQParticipantIf the same pseudo-time step is used for all equations (default), we can access the pseudo time step with: DUAL_TIMESTEP; which is defined in flow.h We can also access the time scale factor defined in the GUI with: RP_Get_Real(“pseudo-auto-time-step-scale-factor”);
- Skewness in ANSYS Meshing
