March 17, 2023 at 9:00 am
FAQ
ParticipantNo. The through-thickness stress due to pressure is not reported for SHELL181, because that stress is not computed. This procedure is consistent with most other commercial finite element codes.
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench Meshing Virtual Topology
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How to use ANSYS Workbench for Shell Meshing and Editing
- What is the difference between shell 63 and shell 181?
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Merging Mesh Nodes
