June 5, 2023 at 7:05 am
FAQParticipantIn the list of supported OS given on ANSYS website (http://www.ansys.com/-/media/Ansys/corporate/files/pdf/solutions/it-professionals/platform-support/platform-support-by-application-18.pdf?la=en), both versions (desktop and server) are supported for ANSYS Products.
