Is the cluster 2 cluster approach supported for non-conformal interfaces with S2S model? Can symmetry be handled? How is this done?
June 5, 2023 at 7:05 am
FAQParticipantS2S model supports cluster 2 cluster approach with non-conformal interfaces. However, the number of faces per surface cluster is still limited to 1 for these interfaces/boundaries. Therefore there is no advantage in using cluster-to-cluster. On all other boundaries, FPSC>1 can be used. The symmetry BC is supported in S2S, It is implemented with a symmetric angle (direction Cosine) at this boundary.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
