Is it possible to utilize reference geometry in a 2D cross-section/sketch grid that isn’t on the sketch plane?
June 5, 2023 at 7:05 am
FAQParticipantYou can use “Project to Sketch” tool within Sketching features to project edges on sketch and then use them as reference. Or you can hold down Shift key and hover over an corner and you’ll be dimensioning from that corner.
- Skewness in ANSYS Meshing
