Tagged: 19, fluent, fluent-post-processing, fluid-dynamics
April 5, 2023 at 2:32 pm
FAQParticipantIf you click on the ‘Viewing’ tab, you can go to ‘mouse’ and select ‘long description’. Then, if you have the mesh displayed, you can right-click on a node or a facet, and you will see text displayed to the TUI that contains the information you are looking for.
- Skewness in ANSYS Meshing
