Is it possible to run a Fluent analysis where two completely reacting different fluid zones are separated by a wall?
August 25, 2023 at 12:16 pm
SolutionParticipantThis is theoretically possible using the Fluent System Coupling approach in Workbench. Please see attached resolution document that illustrates some potential coupling situations.
1. 2050385.pdf
- Skewness in ANSYS Meshing
