Tagged: 16, cfx, fluid-dynamics, General, General - CFX
March 17, 2023 at 8:58 am
FAQParticipantThe combination of “Mesh Deformation†and “Porous Domain†is not yet supported. You should be able to set up a case with mesh motion, using a fluid domain with a porous model setup via momentum sources in a subdomain instead.
- Skewness in ANSYS Meshing
