Tagged: 18.2, General, mechanical, static, structural-and-thermal, structural-mechanics
June 5, 2023 at 7:05 am
FAQParticipantYes, the user can increase the number of sampling points for a Path object. This option is available under the details of the Path object of interest, under Construction Geometry in the model tree. Please note that this option is available only when the path is defined either by “Two Points” or the “X-axis intersection” methods. This is not available when the path is defined by an edge.
