Is it possible to increase the number and/or the dimension of mesh elements on the surface of a specific object in HFSS?
Tagged: 19.2, Electromagnetics & Electronics, General, hfss, Length Based, Mesh Operations, Model, modeler
May 25, 2023 at 7:29 am
FAQParticipantYes, it is. The number and/or the dimension of mesh elements on a surface can be modified using a mesh operation on a selected object: -> Select an object; -> Right mouse click -> Assign Mesh Operation -> On Selection -> Length Based -> Check “Restrict Length of Elements” option and set the maximum length of elements; -> Check “Restrict the Maximum Number of Elements”
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- ANSYS HFSS: Creating 3D Components
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to Set “Non-Model” Property to an Object in 3D Layout
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
- How to Create Bondwires in 3D Layout ?
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
