April 5, 2023 at 2:32 pm
FAQParticipantWith the in-built thin wall option in Fluent, radiation heat transfer calculations are not performed across the wall thickness. The total heat flux (convective + radiative) received on one side of the wall is transferred to the other shadow wall (or interface) assuming 1D conduction through the wall thickness. If you intend to model the narrow fluid gaps using this option, the fluid thermal conductivity will only be accounted for.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
