Tagged: 17, fluent, fluent-post-processing, fluid-dynamics
January 25, 2023 at 7:16 am
FAQ
ParticipantIt is possible to import a custom surface in Fluent for post processing purpose (or in order to create an injection on this surface for example). You can use the menu Postprocessing -> Surface Create > Imprint… and use the Read button to read the surface. It is allowed to import .msh , .cas or .stl files. You can then imprint the volume mesh of your domain on this surface. The TUI command: mesh/surface-mesh/read ‘file.msh” can also be used to read the surface.
- Skewness in ANSYS Meshing
