Tagged: 19.1, fluent, fluid-dynamics, General - FLUENT, parallel, udf
May 15, 2023 at 8:32 am
SolutionParticipantYes, it is possible by using the macros MULTIPLE_COMPUTE_NODE_P, ONE_COMPUTE_NODE_P or ZERO_COMPUTE_NOTE_P. For more details refer to the attached document and the documentation
1. 2055374.pdf
- Skewness in ANSYS Meshing
