Is it possible to get the contact force and moment pass through a Bonded Contact Pair in Static or Modal Analysis ?
Tagged: 17, contact, General, mechanical, structural-and-thermal, structural-mechanics
January 25, 2023 at 7:34 am
FAQParticipantYes, it is possible to get the contact force and moment pass through a Bonded Contact Pair in Static or Modal Analysis. Solution > Probes > Force or Moment Reactions Change the Location Method = Contact Region Choose the appropriate Contact Pair and Evaluate the Results. For this Nodal Forces must be requested in the Output Under Analysis Settings before solving the model.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
