Is it possible to get the contact force and moment for a Bonded Contact Pair in Static or Modal Analysis ?
March 2, 2022 at 3:29 am
FAQParticipantYes, it is possible to get the contact force and moment passed through a Bonded Contact Pair in Static or Modal Analysis.
1) Insert “Solution > Probes > Force or Moment Reactions”
2) Change the “Location Method = Contact Region”
3) Choose the appropriate Contact Pair and Evaluate the Results.
For this, Nodal Forces must be requested in the Output Under “Analysis Settings” before solving the model.
