Is it possible to fix values of species at some domains where I know the species values? I’m trying to save computational cost.
April 5, 2023 at 2:32 pm
FAQParticipantSelected equations can be disabled globally using an Expert Parameter, however there is no option to disable the solving of equations on a per domain basis. If the intention is fix a variable value (e.g. velocity), a source term can be added to its equation. This will not result in solution speedup, however. For example, the following momentum source can be used to achieve a velocity [uspec,vspec,wspec] within a given subdomain : MOMENTUM SOURCE: Momentum Source X Component = -C*(u-uspec) Momentum Source Y Component = -C*(v-vspec) Momentum Source Z Component = -C*(w-wspec) Momentum Source Coefficient = -C END A similar approach can be used for other solution equations, such as AV’s. The idea behind this approach is that we create a source term with a very large, negative source coefficient. This allows it to dominate the equation and force the value of the dependent variable to the specified value.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
