Tagged: 2019 R3, mechanical, meshing, modeling-and-meshing, structural-mechanics
March 17, 2023 at 9:00 am
FAQ
ParticipantYou cannot define a line body, 2D plane strain body, or 2D axisymmetric body as rigid, except in an Explicit Dynamics analysis, 2D plane strain and 2D axisymmetric bodies may be defined as rigid.
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- What is the difference between shell 63 and shell 181?
- How to use ANSYS Workbench for Merging Mesh Nodes
