Tagged: 19.2, Antennas, Boundaries, Electromagnetics & Electronics, Explicit Array, hfss, lumped-rlc, Other
May 25, 2023 at 7:29 am
Solution
ParticipantPlease refer to attached document
1. How%20to%20Consider%20Antenna%20Element%20Just%20as%20Load.pdf
- ANSYS HFSS: Designing a Dipole Antenna – Part I
- ANSYS HFSS: Designing a Dipole Antenna – Part III
- How to export far field data in ffd format and not csv or txt?
- I defined a Master/Slave boundary condition for a unit cell but get the error : Matching boundary process might encounter unexpected conditions because the contact maps are ambiguous. What could be the reason?
- ANSYS HFSS: Antenna Synthesis from HFSS Antenna Toolkit – Part 2
- ANSYS HFSS: Overview of Antenna Simulation – Part 1
- Importing 3D Far Field results within HFSS
- How to export ffd from HFSS and import it into EMIT
- ANSYS HFSS: Link With Optenni Lab
