Is it possible to change the transparency of beam profiles and have them displayed as opaque in SpaceClaim?
June 6, 2022 at 9:58 am
FAQParticipantThe beam profile that appears (if you have the beam Display style set to Solid Beams) in SpaceClaim as a transparent entity is just a preview of sorts, it is not a solid you can grab or alter. You cannot make this beam profile “preview” be non-transparent. The beam line itself is the entity that contains the beam properties. If you want to display that beam profile as non-transparent, as a workaround you could create a new solid with the same dimensions of the beam preview.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
