January 25, 2023 at 7:34 am
FAQParticipantIn general, bolt pretension can be applied to beam elements, but there must be more than 1 element along the length. One cannot apply bolt pretension to Beam Connections in Workbench Mechanical since these internally create a single beam element. However, one can define bolt pretension loads to line bodies created in DesignModeler.
- ANSYS Mechanical: Node Merge
- How to use ANSYS Workbench Meshing Virtual Topology
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- ANSYS Mechanical: Node Move
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to use ANSYS Workbench for Merging Mesh Nodes
