Tagged: 18.2, fluent, fluid-dynamics, General - FLUENT
March 17, 2023 at 8:58 am
FAQ
ParticipantIn Fluent solver and Fluent meshing, the command /file/set-tui-version “XX.X” allows you to hide any new TUI prompt that was added in a future release, and revert to the arguments of the release specified with the command – the command cannot be used to revert back to a version prior to 18.1 – the command itself is available from version 18.2 onward – if some commands were removed in the later release, the command will not address them, they must be addressed manually The command should be invoked prior to reading the journal file or added on top of the journal file. It is added automatically to a journal file as soon as a recording is started. You can find additional information to create a journal file in the documentation : https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v193/flu_ug/tgd_user_file_journal.html
- Skewness in ANSYS Meshing
