April 13, 2023 at 7:33 am
Solution
ParticipantYes, this can be done using a User Defined Result. Please refer to the attached document and example model.
1. 2058953.pdf
2. 2058953.zip
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
