Is it possible in Mechanical to define a Heat Flux on a surface as a Gaussian function of a spatial coordinate?
Tagged: 19.2, mechanical, structural-and-thermal, structural-mechanics, thermal, transient
March 17, 2023 at 1:11 pm
SolutionParticipantYes, this can be done with APDL commands. Please check the attached model that includes a fully commented ADPL script.
1. 2058386.zip
