Is it advisable to use “small sliding†option for a nonlinear contact pair in bolt pretension applications?
Tagged: 19, contact, General, mechanical, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 amFAQParticipant
Yes, but one must make sure that the differences in mesh densities between the contact and target surfaces are smaller than the amount of sliding experienced.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
- How to define frictional coefficient as a function of relative sliding velocity
