June 5, 2023 at 7:06 am
FAQParticipantThe process of certifying Creo 4.0 for R18.0 is nearly complete. The plug-in works, but we’ve determined there may be some installation configuration issues, but not for all machines. Below are the specifics with recommended work-around. Issue 1: Installer does not recognize Creo 4.0 as a valid CAD install. Workaround: Choose “Perform configuration at a later time”, and then use CAD Configuration Manager to setup the plug-in after installation is complete. Issue 2: CAD Configuration Manager fails. Workaround: Perform manual configuration by following the steps in Help section 9.1.5, Creo Parametric Configuration: Add an entry into your config.pro file like this: PROTKDAT E:Program FilesANSYSDevANSYS Incv180aisolCADIntegrationProEProEPagesconfigWBPlugInPE.dat Create a WBPlugInPE.dat file identical to the example provided in help. Create an environment variable PROE_START_CMD180 which points to the bat file used to launch Creo, typically this is C:Program FilesPTCCreo 4.0F000Parametricbinparametric.bat. We are only declaring support for 18.0, but I would expect the behavior to be incidental in 17.x – it should work with the same install/configure considerations.
