Is “Circumferential Divisions” available for tetrahedron elements for Semi-Elliptical Crack definition?
June 6, 2022 at 9:58 am
FAQParticipantCircumferential Divisions are available only when user chooses Hex Dominant method for Semi-Elliptical Crack definition. If tetrahedron mesh is chosen, crack front divisions are defined via crack front size and circumferential divisions are not required for this method.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
