March 17, 2023 at 9:00 am
FAQParticipantNo, the mass associated with the in-plane rotational DOF (ROTZ) is set to zero. SHELL181 does not have physical stiffness for the in-plane rotational DOF (i.e., drilling DOF). To deal with arbitrarily oriented shells, a small drilling stiffness is used. However, the stiffness is very small, so any mass associated with the drilling DOF could produce spurious modes (SQRT(k/m)). Therefore, ANSYS removes the mass associated with the in-plane rotational DOF.
- ANSYS Mechanical: Node Merge
- How to use ANSYS Workbench Meshing Virtual Topology
- ANSYS Mechanical: Node Move
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How can you identify the element types used by Mechanical?
- What is the difference between shell 63 and shell 181?
- How to use ANSYS Workbench for Merging Mesh Nodes
