March 17, 2023 at 9:01 am
FAQ
ParticipantNeither ANSYS 10.0 SP 1 nor ANSYS 11.0 will be supported with Windows Vista. ANSYS 11 SP1 allows you to install on a Vista 64-bit platform.
- Q: How do I set the license server from my client machine?
