September 24, 2025 at 9:55 am
FAQParticipantAnsys Discovery consists of exciting features for designing and optimizing systems consisting of Internal Fans. It enables engineers to achieve the best possible performance within defined constraints. Using physics-based simulation driven by fan curve and geometrical features, Discovery’s GPU solver helps you quickly evaluate the fan performance and select appropriate fans CFM, fan placement.
Please refer to the following pdf for detailed knowledge article Internal Fan
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Discovery – Defining new material
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Structural Simulation using Bolt Idealization
- Thermal Analysis of Heat Sinks with Ansys Discovery
- Discovery Quick Tip- How to Export to Fluent
