Intel MPI fails during Fluent start-up for some machines running on SUSE Linux Enterprise Server 15 SP1. BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES PID #### RUNNING AT host2 EXIT CODE: 11 CLEANING UP REMAINING PROCESSES YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
Tagged: 2020 R2, FLUENT - SYS, HPC/Parallel, Installation/Licensing/Systems, N/A
January 25, 2023 at 7:28 am
FAQParticipantThis is a known limitation of Intel MPI with SUSE Linux Enterprise Server 15 SP1. It appears as the following in the KIL doc: ————————————————- This is a known Intel MPI issue with no known solution and is indicated when a message like the following is printed in the console before the Hostname table. BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES PID #### RUNNING AT host2 EXIT CODE: 11 CLEANING UP REMAINING PROCESSES YOU CAN IGNORE THE BELOW CLEANUP MESSAGES Workaround: Use openmpi using the following flag: -mpi=openmpi ————————————————-
