January 25, 2023 at 7:28 am
FAQParticipantMicrosoft update KB4571756 results in one of the Windows functions (DescribePixelFormat) crashing on startup. For versions 2018.0 and newer, set the following environment variable to get around the problem: ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL=1
