Tagged: 18.2, cfd-post, fluid-dynamics, Turbo Post-processing
June 5, 2023 at 7:05 am
FAQParticipantTurboPost will have issues initializing on geometry containing sharp kinks. It was defined for main flow path geometry where the meridional definition is generally based on smooth curves. Other geometries, with backface geometry with labyrinth seals will fail due to kinks in the hub/shroud curves defining the meridional geometry.
- Skewness in ANSYS Meshing
