June 6, 2022 at 10:51 am
Watch & Learn
ParticipantIn this video, we will talk about how to deal with contacts that appear even when you have shared topology turned on for the bodies and you are expecting a fully connected model. This can happen due to tolerance issues. Even though the bodies may have been placed in the same component and the topology shared since there is a gap between some of the bodies they show up as unconnected geometry and a list of contacts are created at those locations.
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Create Sections in Meshing
- ANSYS ICEM CFD: Basic Blocking
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is meaning of message: One or more objects may have lost some scoping attachments during the geometry update.
- What is the difference between patch dependent meshing and patch independent meshing?
